Carpet I like to vacuum but not mop
I run my vacuum and mopping separately on two different schedules. It is possible to set a zone of carpet for vacuum only. And when the mopping mode is on it avoids the carpet zone? I tried using “no mop” but then the vacuum mode avoids the area. I tried “dynamic lift” with mop mode and the Roborock goes over the carpet zone with the mop lifted. This is wasting time and battery as it is not vacuuming or mopping on the carpet.
  • Thanks for posting.
    In Dynamic lift mode, robot will lift up the mop bracket and still vacuum the carpet.
    If it's not vacuuming the carpet, would you please go to carpet setting and enable carpet boost mode?
MasterVic
