Roborock S6
 I've bought a Roborock S6 several weeks ago, why does map not show rooms with different colors on map?
  • Hi, there are 4 requirements for robot to divide room on map.
    When robot is creating the first map,
    1. Map saved mode is enabled, see attached pic1.
    2. Robot starts from dock;
    3. Robot goes everywhere on map it detects to clean, not just somewhere;
    You could also try to divide rooms manually, see attached picture2.
    Like3
buce
