Problems after last updates -
After the last updates, the S5 Max started to behave strangely, even after cleaning the sensors and factory reset I have noticed the following problems.
- Places where it used to make a closed curve (corners) now makes it open and rounded
- In certain places, a straight line does not pass closer to the wall or furniture, when close it is more than 15mm away, which did not happen before, doing a zigzag
 obs: I already tried to create new maps to correct the problem but it didn't work.
KAKA
