Roborock q5 incomplete passes
My Roborock q5 routines are set to clean a room in 3 passes (3x). It has been doing that just fine until I adjusted the map/rooms to reflect the actual room locations. Of course when I did that it deleted previous routines. So I set up the routine like it always had been, vacuuming the room in 3 passes (3x). Now it will only do 1 pass and not 3. How can I get it to do 3 passes again?
    Thanks for your feedback. We are sorry for the trouble you are facing.
    Your question may not be solved in a short answer. We suggest you contact us via email: support@roborock.com. You could attach related pictures or videos in email to help us understand your question.
nikkiekoala
