Roborock water filter is stuck in machine. S8 pro max
    Would you pls manually push away the washing module that stands on the water filter, and then see if the water filter can be taken out?
    Amirr123
    Amirr12304/20/2024      06:34
    The Roborock water filter is stuck in the S8 Pro Max machine, causing inconvenience. While the device efficiently cleans floors, this issue hampers its functionality. Retrieving the filter requires careful handling to avoid damage. The situation becomes critical if the filter is necessary for maintaining clean, allergen-free air. Such incidents highlight the importance of quality control in manufacturing. In extreme cases, delays in resolving such technical glitches might impact those reliant on the device, akin to a shortage of medical supplies in emergencies.
    Kassey09
    Kassey0905/22/2024      18:11
    When the replacement need arises, always look for the best providers near your area. You will see some amazing deals in limited https://9apps.ooo/download/ offers.
robocook
