Is there an easier way to add a room to the map that was not originally scanned (due to a door being shut) other than having the vacuum run through the entire house again and remapping the whole house?
Set room cleaning or zone cleaning with this specific room included and verify whether the map will update it automatically.
Otherwise, I'm afraid that you need reset the current map and re-map the house.
When robot is creating the first map,
1. Map saved mode is enabled.
2. Robot starts from dock;
To map (add) a new room without remapping the whole house, follow these steps:
Have robot spot clean using "Pin N Go" an area inside the room or at least at the door. Send robot back to dock once done. The new room will show as a grey area.
Set a zone clean than encompasses entire room plus additional few extra feet on at least two sides. Let robot finish and return to dock.
Choose edit map and then "Edit Room". At the top right select "Re-Split Rooms". The new room should be added and all room can be divided and named.
Sounds like a good idea!
