Roborock s5 max not connecting to the network
Hi, i have been having a problem with my s5max. It doesnt want to let me connect to the network. I tried both the roborock and mi home apps. It still didnt work well
Is there any suggestion? What should i do?
    We can use Roborock app do some troubleshooting first.
    1. Make sure the wifi password you've input is correct.
    2. Don't use an android tablet, iPad, iPhone 5 or iPhone 5C to connect the robot as there might be compatibility issues.
    3. Enable location permission like in attached picture. If it is iOS 14.0, please enable "local network" permission for it as well.
    4. Pay more attention to the select wifi step. See attached picture "select your home wifi".
    5. If there are special characters like !@#$ contained in your wifi name or password it is suggested that you log in to the router and remove them in the wifi settings.
    6. The robot doesn't support WEP encryption mode. If your wifi is WEP, change it to WPA or WPA2.
    7. If you understand the router's setting well then change DNS to 8.8.8.8 in the router's settings page.
    8. Reboot your router, your robot and try again.
    Also, you can connect it to the mobile hotspot.
    rdog
    rdog02/22/2021      01:47
    Same issue for me. The roborock s5 max was working well for 7 months, but as of last week, I'm having this same issue. Nothing has changed - it just stopped connecting for some reason. Any further tips? I have tried most of these things.
    RR_SupportStaff Member02/22/2021      09:26
    @rdog:
    Hi, have you tried connecting the device to a hotspot? Can it be connected to a hotspot?
    Venom2134
    Venom213412/06/2021      01:25
    @rdog:
    I'm having the exact same issue you're experiencing. It worked well, connected to the same wifi for a couple of months and suddenly it cannot connect. I'm assuming a firmware update created the problem..
mel
