I try to start the S 5 and found the device always offliy..and later become network slow when loading the map. I am keep waiting till the apps asked me to login. I try to login and then show betwir is unavailable! Is anything wrong with the apps?
3. Take the robot off the charging dock, reboot it by long hold the power button and run the app again to see if it works.
4. What is the size of your house? not size already cleaned, but your house's whole size.
5. If you are using Mi Home, tell us which region your Mi Home selects and switch region to the US or Singapore, then re-connect the robot to Mi Home. See attached picture.
6. Clear cache of app. See attached picture.
7. Reinstall app to have a try.
8. Please use your phone data instead of wifi to see whether map will show up.
9. Do you have any other Xiaomi's device, like camera, lamp?
