ROborock S5 - Connection Timed Out after installing recent firmware update
After having updated the firmware on Friday, today I wanted to clean my flat. Unfortunately, I keep getting the "Connection Timed out" error. Already tried reseting my router, wifi settings in Roborock, resetting the cleaner to factory settings, adding it as a new device, and reinstalling the app on my iPhone but nothing helped. Funny fact - when I press the entre button, it cleans the flat but I still can't connect it to my network to direct it to a specific room. When I add it as a new device, it's successful but it still doesn't connect to network. Please help as I already wasted two hours trying to figure out what's wrong...
  • Oh and my region is set to Germany (don't know why, I live in Poland but when I installed the app a few years ago and then added all the devices, the app asked me to set this region. Everything had been working fine until today).
    jack
    jack02/21/2021      20:57
    @Arek:
    I have the same problem with Roborock6 in polish version of Xiaomi Home. First there was app info that network is working to slow but all other devices working on 2,4 WiFi are working as usual also internet speed is normal. I had to remove roborock from app, reinstall app but I cant add roborock again. Please help me !!!
    jack
    jack02/22/2021      07:43
    @jack:
    OK so i had to connect my smartphone directly to Roborock local Wi-Fi network and then i was able to add vacuum to Xiaomi Home manual.
  • Hi, thanks for your reply.
    Can you please try connecting the device to a hotspot to see if the issue will go away?
    You need to first get 2 smart phones( A and B) .
    RR_SupportStaff Member02/22/2021      08:27
    "Funny fact - when I press the entre button, it cleans the flat but I still can't connect it to my network to direct it to a specific room." Could you please tell us which button you pressed? Is it a physical button on the robot or any button in the app? Maybe you can send us a screenshot or a picture to show it.
Arek
