S5 Max Water Tank stops dispensing water when the tank is 2/3 full
I have a S5 Max for less than a year and everything worked fine until today. When I do my regular cleaning routine, I noticed that my device stopped moisturizing the mop pad when the water tank is still 2/3 full. The mopping function working totally okay when the water tank is full. I followed the troubleshooting instructions and check the airholes and water holes but can't fix the problem. My firmware is updated to the latest version. Does anyone encounter the same problem?
    May I know if you've contacted our support e-mail? support@roborock.com
    If no, would you please keep using the 2/3 tank of water, and check if the water can run out in the end?
DL59
