My roborock s5 max have navigation problem, if i dont put mopping mount and cloth everything fine.
But if i put mopping mount and cloth the problem occur.
Can anyone help me?
Thanks for reaching out. Please try the following:
1. Could you please lower the water level and test if the robot can work fine with the medium water level?
2. Please empty the water tank and a dry mop cloth, and install them to the robot to see if the issue will still exist.
1. I already lower the water level but still have the same problem.
2. If i take off the mop cloth, it working fine!I
try to cover the tire with something and put the mop cloth with low water level and everyhting working fine.
I think the main problem is the rubber tire dont have enough grip.
Glad to hear that you figured it out!
I personally agree with you the issue may lie in the wheels. We suggest you keep observing the robot's performance for a few more runs. If there's anything else that we can help with, pls feel free to contact us.
hi
Hi, thanks for reaching out. Is there's anything we can help?
hi
hi
