Hi!
I have a Roborock s5 Max and it is working perfectly well with Alexa using Skill Roborock Plus in Portuguese
I would like to create routines in Alexa using The S5 Max, but it seems that there is a problem to use Roborock in custom actions in alexa in Portuguese
Custom actions are used within the routines, using phrases exactly as they are said to alexa, eg Alexa, ask robot rock to clean
It turns out that even using terms identical to those that work in voice command, it doesn't seem to work within the routines
I tried changing the alexa language to english and in this case the custom actions within the routines work But there seems to be a problem with the Portuguese language
Could you give me instructions on which phrases in Portuguese I can use in writing within the routines (where "peça para o roborock limpar", "peça para o robo rock limpar" don't work...
(imagens as a working routine in english, same dont works in Portuguese... )
We noticed that you've already contacted our support e-mail. Please stay tuned for the reply via e-mail
