Roborock S6 bad noise
Hi there!
Recently my roborock started making a strange noise, loud too. I tried taking apart and reinstalling the main brush but it didn't help. All the parts have been replaced 2 months ago so that's not the issue. Brief video link:
https://youtu.be/DOSv0zs7g0o
Any suggestions?
    The abnormal noise could come from several parts. Please try the methods below to rule it out first.
    1. Run the robot without the main brush or its cover to see if the noise still exists. If it comes from the brush, please clean it according to the video below.
    For S4, S6, S6 Pure, S5 Max, S6 MaxV
    https://drive.google.com/file/d/1enzwg48u8tqvkkAZO_iHg4uGEFTKxHGf/view?usp=sharing
    2. Unscrew the side brush and run the device without it to see if the noise still exists.
    3. Uninstall the front wheel.
    For S6, S6 Pure, S5 Max, S6 MaxV, E4, S4 Max, S7, E5, try to uninstall the front wheel according to the video below: https://drive.google.com/file/d/1hRxkV8erMXfxyKkkBu-LaHThWe6hJY98/view?usp=sharing
    For C1, E2, E3, S5, S4, just uninstall the front wheel by hands.
    Run the robot without the front wheel to see if the noise is gone. If the noise comes from the front wheel, please check the video below to clean it and drip oil into the inside of the wheel.
    https://drive.google.com/open?id=1t3NM5udCZA6Z2Bro9tlwUK8SWeL4u0_Z
    4. Press and turn the two wheels like the attached picture to see if there is any noise.
    5. Clean the filter and change suction mode to the lowest to see if the noise will go away.
    If the issue persists, would you please reach out to our support team at support@roborock.com so that we can better assist?
    Robbman83
    Robbman8302/10/2023      06:02
    I have the same problem. The sounds come from the dustbin area. When ibremove that the sound go away.
    Cant see that anything is loose or strange.
    Any suggestions?
    RR_SupportStaff Member02/26/2023      10:44
    @Robbman83:
    Thanks for reaching out. You may try the following: Please use compressed air or a hairdryer to clean the fan intake area. You need to take out the dustbin first and the fan intake is at the left or the backend area. see attached picture
Marcello
