Software issue: multiple maps
I’m two days into my new MaxV 7 ultra. It works great but I can’t figure out how to create multiple maps. I thought I could just copy my one good map, give it a new name and program it. But when I renamed it I just lost my previous map. So so far I’m just stuck with one map. Can anyone help?
  • I am also interested to know more about these issues.  Does anyone have any recommendations with previous experiences?
  • Hi, thanks for reaching out. Here's the instruction on how to create multiple floor maps.
    First of all, please make sure there's WIFI coverage on the other floor.
    If there is, kindly follow the steps below to create the multi-floor maps:
    1. Tap the "Edit map" button on the bottom right corner of the map, and choose "My Map" from the pop-up banner.
    5. Make sure the robot is now located on the other floor. Then press "Create", and "Clean". The robot will speak "Starting to clean". Please wait until it completed the cleaning, and don't manually move the robot or interrupt the process.
    You can check the attached screenshots for your reference.
Robby2
